CODES...Don't know where to start?? - Ford Powerstroke Diesel Forum
Old 07-20-2010, 02:54 PM
2001 F350 7.3 manual trans, 126,000 miles. I don't know where to start. Used Modis with K 20 key.
codes present
P1277, P1274, P1226 high to low side open?
P1211 ICP above/below desired
P1209 Injector Control Pressure System fault
P0603 Injector Control Module KAM error
P1316 IDM codes detectedInfo from scanner.
RPM 680
DTC 4
AV (v) .62
Baro "HG 29
Baro (V) 4.52
Baro (HZ) 81
EBP 14PSI
EBP V .90
oil temp 147
oil temp (V) 1.92
FuelLPW 1.63
IAT (V) 2.33
IAT F 93
ICP V 2.40
Inj Cnt Pres 1800
MAP PSI 14
MFDES 16
SCCS v 6.85
SCCS open
Ok what do I start with first. The computer told me to fix some before others, Not the smartest with this so whats the fix for them?
I have replaced the CPS, ICP sensor, MAP and rebuilt the turbo. I also broke the EBPV and will get a new one from Ford tomorrow.
I love this truck.
thanks
Old 07-20-2010, 03:19 PM
Is the truck stock? Chip? Programer? Need info dude!
Old 07-21-2010, 11:18 AM
all stock!!!!!!!
Old 07-25-2010, 08:05 PM
sounds to me like a faulty IPR but not 100%
Old 08-01-2010, 10:10 AM
remove your IPR valve disassemble clean and reinstall it also your EBP is way to high remove and clean your EBP sensor and tube reinstall and retest
Old 08-01-2010, 10:22 AM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
dang! thats alotta codes dude!!!! good luck dude!!!! just kidding, there is a post in here fer all the code meanings,start with one and go threw the process of elimination
