how long should i crank engine - Ford Powerstroke Diesel Forum
Old 07-20-2010, 01:43 AM
aloha i recently changed hpop o rings as well as rings for pedestal and injector. i also deleted ebpv. i have put everything back together and tried to start but it does not fire up. how long should i hold the starter, and do i have to pull the harness while i am turning key at first. thanks in advance.
Old 07-20-2010, 01:50 AM
dont hold it down or you will drain batts and burn up the starter.
keep the hpop tank full and that should help it.
leave the harness plugged in.
Old 07-20-2010, 08:30 AM
ya did you refill the hpop?
