Stalling, no accelerator - Ford Powerstroke Diesel Forum
Old 07-15-2010, 04:22 AM
Ok, on my way home, i go it up to 70 but it seems as soon as i get to a steadt speed it wants to start acting up like its missing, and in town if i stop at a light or let off the pedal, and get back on it, nothing.... than the "service engine soon" light popped on. i have to keep hittin the pedal than away we go. just seem like its not running smoothy at hight speeds. any suggestions or where to start? BESIDES the Ford place. also i tried playing with different setting on the tuner (edge) but it just seems worst or the same on higher setting.
Old 07-15-2010, 10:04 AM
there is a class action law suit about this issue, I don't have the info with me but if you look it up, you can sign up for it. Basically they will pay for any costs you might get from the shop.
Old 07-15-2010, 10:17 AM
IS THAT THE recall i received no long ago is that what that is about???
Old 07-15-2010, 10:36 AM
It's a moral issue.
If you want to help make some lawyers rich, feel free to sign up for the CAL.
Hopefully, some peoples' conscience won't allow them to participate in the crime of "ambulance chasing".
Old 07-15-2010, 10:41 AM
i JUST want the problem to go away. I'm picking up some bolts for the Ford place today i may pick up a cmp Because i noticed at lunch, after reading some info on bad cmp's about the rpms not moving while cranking. article said it should,,,,,,,, mind doesn't And i uplugged mind to do my water pump and since than its really getting bad. every day instead of rarely. looks like and easy change But i need to see what that recall notice was first If its that than i'll save some $$ b4 i decide if thats the problem
Old 07-16-2010, 06:09 AM
oK. I did a walk thru on my truck yesterday jut checking all connections. drained the fUEL BOWL and checked filter. But what i did notice was i had some diesel around my fuel to tank connections. seems the clamps had come loose. wiped it off re-installed clamps. came in to work this moring and not one stall or hick-up. Could a leaky fuel line like that cause problems????? sucking air maybe????
