back yet again
so its been a long time since i posted anything about my 99psd well after i rebuilt the motor while on the initial break in drive it died. got it back home and then it started one last time. so i put on another wiring harness and it just cranked and no turn over. bought a new cps sensor and it still just cranked. i forgot to add in there that while i put a new cps sensor i forgot to plug it in, relized it and plugged it in. well now the truck just cranks, it doesnt even want to start. can any one shed some light on my situation?
Do you have oil in the Hpop res?
yeah it has oil in the hpop resovoir. it just dont want to actually crank over.
The fuel bowl has fuel in it?. Somtimes it takes a bit to run all the air out of the oil and fuel systems. Do you have it hooked to a battery charger? How fast is it cranking? what type of startup procedure did you do? How long did it run before it died the first time?
fuel bowl is full, the fuel pump is pumping, i have replaced the batteries 2 times, i have another deisel truck hooked up to it while i try to start it. it doesnt crank the engine over 200rpm its kinda strange. i have even tried to plug it in to keep the oil warm but that too was unseccesful. i know i need to replace the pully on the powersteering pump because that backs off on its own. but other then that i know it had a fuel knock coming off the passenger side of the block. when i put the first oil in it , it was 13qrts of delo 15w40 and 2 qrts of marval mystery oil. so i drained it and put 15qrts of regular 15w40 and since doing so i havent even got it to turn over long enough to see if the new oil helped. as for the first time it died it drove 3 miles and then died. then when i got it home and plugged my little battery charger hooked up and then it cranked and started and ran for about 15 minutes and then i shut it off and did the other things to it.
Check for high resistance in your battery cables, it is sounding like the starter isn't turning it over fast enough, and the ecm isn't happy about it.
When my 01 finally didn't want to start without extended cranking, I bought a new starter, stuffed it in there, and it whirled over like a turbine, fired right up. I had already built a new positive cable, and will do new grounds as I put the new engine in. |
