Starts when cold shuts down when warm - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-28-2010, 05:19 PM Thread Starter
alrocky's Avatar
Unhappy Starts when cold shuts down when warm
I have a 04 7.3 F250. I was driving along then vehicle shut down like ran out of fuel.
Towed to mecahanical garage, have replaced CAP sensor, HPOP sensor, engine coolant sensor appears to be okay when checked, checked IDM, checked computer, replaced air filter, fuel filter, changed oil and filter, checked relays and all seem to be okay. Fuel pressure is reading 60psi when running and when it shuts down. Have ordered replacement oil temp sensor to be fitted Monday.
The vehicle starts when cold, then when it warms up (about 15to 20 minutes it shuts down.
Can anyone give me any other suggestions, the mechanic is scratching his head in bewilderment.
*****Thanks for your responses folks, cannot believe for 4 weeks it was in the garage because of a faulty solnoid on the IPR. Gotta get me a decent scan tool so it doesn't happen again. Just glad to be back on the road. Ye hah!
alrocky is offline
post #2 of 11 Old 05-29-2010, 06:25 AM
First of all - you do NOT have a 04 7.3 F250. The 7.3 was discontinued mid run in 2003 and I have one of the last 7.3 trucks to roll off of the line. So verify what motor / year you have. It will make a big difference in diagnosis.
2003 F-250 XLT CrewCab 7.3, Chrome BigTex Grille Guard, Quad pillar - 3 ISSPRO gauges (trans, pyro, boost) and DP-Tuner F6, Ford Severe Duty AIS, 31 row 6.0 transmission cooler (not the sissy 26 row)
, ScanGauge II
dray8165 is offline
post #3 of 11 Old 05-29-2010, 05:47 PM
While the 6.0 is more prone to this problem the 7.3 also could do it. Damage to the copper gasket on the end of the injector allows combstion gas to enter the fuel passages and forces the fuel out causeing the injectors to starve of fuel. Also the hold down bolt backing out or stretching can allow the injector to unseat. This is one problem that is hard to catch in the act.
A quick test disable the fuel pump and IDM so it can't start. Remove the top filter cover and filter. Have some one roll the engine over and watch for bubbles. If bubbles are present you are getting combustion gas in the fuel rails/passages.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 11 Old 05-31-2010, 12:44 AM Thread Starter
alrocky's Avatar
Sorry, my mistake, I am actually in the "land down under" Australia, I am informed that when the vehicles arrive here from over seas, they are issued with a new compliance plate and stamped with the year they are first registered here, so if it is a 2003 model , it may not have been complianced until 2004, hence it has a 7.3.
The mechanic that is trying to fix it, has created a thread under aussierockymechanics.
alrocky is offline
post #5 of 11 Old 06-02-2010, 11:49 AM Thread Starter
alrocky's Avatar
Angry
The mechanic has put in the new oil temp sensor, no change, new kit in the injection regulator , no change, checked all earth connections, it seems that when it gets to running temp it shuts down, could it possibly be the ect sensor sending wrong signal to the computer , such as temp too high??
alrocky is offline
post #6 of 11 Old 06-03-2010, 07:08 PM
I assume you mean engine coolant temp sensor by ect? Unless it is a manual transmission, there is no such sensor on your truck, just the sending unit for the gauge which does not communicate with the PCM. And if it is a manual and you do have a coolant temp sensor I do not think it has an overtemp shutdown feature.
I asked your mechanic if he checked the high pressure oil system but he didn't answer. Hopefully the electrical expert he is sending it to can get some data from the PCM, it's pretty much a guessing game without that data.
2002 F350 4x4 Crew, coolant filter, 6.0 tranny cooler and ext. filter, pre pump mod & filter, Isspro pillar pod, EV-2 hpop & fuel pressure gauges, AIS, Marinco x2, door seal mod, netbook mount for AE.
bigb56 is offline
post #7 of 11 Old 06-03-2010, 10:53 PM Thread Starter
alrocky's Avatar
Thanks, was not aware that on the auto it only sent to the gauge, the mechanis has an auto electrician checking a few things on Monday extracting info from the computer so wait to see what data comes from that
alrocky is offline
post #8 of 11 Old 06-17-2010, 02:22 AM Thread Starter
alrocky's Avatar
Scan tool inquiry
Come Monday it has been 4 weeks at the garage trying to be fixed, it has been with the auto electrician for the last week, they have run tests on the computer and all appears to right, they believe it is an electrical problem so I am waiting still!!
I have made inquiries on the net regarding the autoenginuity tool with the Ford F series bundle, can anyone tell me whether it is the best diagnostic tool on the market, I want an instrument/programm that will be able to tell me what the problem actually is so thbat my truck is not off the road like this time it has been.
alrocky is offline
post #9 of 11 Old 06-17-2010, 02:29 AM
Other vehicle is an F250
Hank's Avatar
I really like my AutoEnginuity. In fact a fellow org member is dropping by my place tomorrow to have me calibrate his speedometer that FORDsaid couldn't be done because of his 38" tires. The AE will do it! Saturday I will be scanning another kid's truck to check a code he has. I think it is a great toola nd the guys that write the programs are the ones that answer the telephone when you call. Good luck. I posted in your other thread.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #10 of 11 Old 06-17-2010, 02:51 AM Thread Starter
alrocky's Avatar
Thanks for that, the fellow that I have been dealing with from over there in USA has given me a distributor contact here in Australia to see if they have it in stock, otherwise I have to purchase via the USA and have it shipped.
Cheers
alrocky is offline
