hesitation/surging/bucking 2001 F250 7.3L 4x4 - Page 9 - Ford Powerstroke Diesel Forum
post #81 of 94 Old 08-25-2010, 08:08 AM
shmuckaluck's Avatar
Hey guys,
just wanted to make sure that I let everyone know that my truck wasn't fix by the HPOP, after i changed that i got it started but i ended having more problems, so I said F-it and took it to the dealer. It ended up being my #4 injector was leaking and causing low oil pressure on that side of the motor. so don't spend 500.00 on a HPOP like I did unless you know for sure, I had a ford guy tell me after some testing that he was sure it was the HPOP. some times it's just easyer to take it in, as much as we hate to do it. it cost me 1,100.00 for the injector and a coolant temp sensor and labor.
shmuckaluck is offline
post #82 of 94 Old 08-25-2010, 09:44 AM
Chapter Director
freeride707's Avatar
Thats what im thinking mine is too because ive been noticing a little oil/fuel seeping out the valve cover so when i pull the VC off to change GPs i will check the injectors orings etc
E99 F250 7.3l CC SB 4x4 Lariat,8.5" lift, dual reservoir shocks toyo my 37's gear alloy 20x12's,TW chip,5in exhaust,DIY intake,BTS trans,HPX, frx gauges,Powerslot rotors w/hawk pads,Tint,08 emblem vents,Custom paint,05 Harley front w/ custom grill, shaved 08 step gate and tinted tails, spray-in bedliner
WCS Assistant Director
freeride707 is offline
post #83 of 94 Old 08-25-2010, 11:21 AM
Originally Posted by dray8165 View Post
If I were betting on it, I would bet you've got one or more injector o-rings out.
Well I be - way back on page 1 - guess I win the prize.
2003 F-250 XLT CrewCab 7.3, Chrome BigTex Grille Guard, Quad pillar - 3 ISSPRO gauges (trans, pyro, boost) and DP-Tuner F6, Ford Severe Duty AIS, 31 row 6.0 transmission cooler (not the sissy 26 row)
, ScanGauge II
dray8165 is offline
post #84 of 94 Old 09-12-2010, 10:41 AM
My 2002 f250 with the 7.3l started to do the sputtering and the surging... and i just change the oil and for the first time i added the lucas oil treament.. and then the promblem started.. change the oil without the lucas stuff... all goood..... so far it hasnt done it... so hopefully that was the problem...
Fleet2904 is offline
post #85 of 94 Old 09-23-2010, 11:55 AM
hey guys just though i would add some of my problem and things i have done to the list.. problem ruff idle and shaking bucking at 1200-2100 rpm range. i changed oil changed hpop and ipr. i then changed injectors harness and plugs. problem has gotten better but i still some times get a little shuddering around 1800rpm but it might be from air in the oil rails. ill post when i bleed oil rains and drive again
cdacaraudio is offline
post #86 of 94 Old 09-23-2010, 01:31 PM
The air will work out of the rail, but will take some aggressive driving to do so...
I just got done rebuilding my engine, and in the process replaced cam sensor, ipr, uvc harnesses, alternator, Engine running like a top.
Dumz1 is offline
post #87 of 94 Old 09-24-2010, 07:03 AM
well the air worked out and the motor is running great now but i have a different vibration now. seems on top of my injectors being junk my carrier bearing is junk to. now to try and find what one fits they list like 5 and last time i had to go back 3 times till i was able to get the old one off and bring it in
post #88 of 94 Old 01-25-2011, 06:17 AM
Hey SpectreZ91, what happened, did you fix it?
Don't u just love it when someone keeps the thread going for 9 pages and then never posts the solution.
My 2000 Excursion has been doing this for over a year and is gradually getting worst. Another thread says it is the TPS but a new one made it worse.
It stumbles between 1300 - 1800 and it is worse when cold. More throttle and it smooths out. Could that be injector o-rings, which seems to be the conscience here.
Sure would be nice if someone that has fixed this problem would post a solution.
bkeese is offline
post #89 of 94 Old 01-25-2011, 06:28 AM
Chapter Director
Just fixed mine last week. It was the under valve cover harness. Truck was only running on 6 cy
post #90 of 94 Old 01-25-2011, 06:41 AM
How did you determine the harness was bad? Did you replace o-rings?
bkeese is offline
