2001 4x4 crew cab 7.3 DTC P1249 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-27-2010, 08:43 AM Thread Starter
2001 Powerstroke DTC P1249
I just pulled this code P1249Wastegate Fail Steady State Test . I have the wiring assy, on order which is the pressure hoses that go from the (red) accuator to the manifold to the (some electronic thing) and (green hose) that goes from the electronic thing to the air intake. I pulled vacuum on the accuator and it held, if any of you have seen this code before and you tell what your fix was? I don't get the pressure/vacuum hose (wire assy) until Wednesday after work. The part I ordered was F81Z-9E498-DA
Thanks guys!
2001 7.3 Dave is offline
post #2 of 8 Old 12-02-2011, 07:24 AM
justinlogue5_0's Avatar
Did you ever figure it out? I have the same problem and all I can find is a ton of unfinished threads dealing with this? Thanks
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #3 of 8 Old 12-05-2011, 07:12 AM Thread Starter
Yes I did figure it out. My truck is a CA truck and it ended up being that part the only the CA trucks had. I wish I could remember the name of it. But it had to plugs the pluged into it. It cost about 250 bucks. I wish I could remember the name of the part. By the way, it is tan and ribbed. It is about 5"x2"1". Made in France or somewhere wierd like that. Sorry I don't have a better answer. I also ended up doing the glow pug harness' and glow plugs. All is perfect now.
post #4 of 8 Old 12-05-2011, 07:34 AM
Oh ok. Thanks.
It never ends!
post #5 of 8 Old 12-12-2011, 10:59 AM
Hey justin, I'm having the same problem with my '99. I'm in the same boat as you are, TONS of threads started, but no follow up on the fix.
If you find out anything, please post as I will do the same. Jeff
18inchapes is offline
post #6 of 8 Old 12-12-2011, 11:06 AM
Do you have a boost fooler? The only thing I can think of is my boost fooler is not working properly and the pcm is picking up an over boost when I am under a hard load. Not completly sure since all I have ever seen is a Max of 20 psi boost? The search continues............
It never ends!
post #7 of 8 Old 12-12-2011, 12:02 PM
No, no fooler, I even took the programmer out just to confirm its not that. I have a thread started about whats going on with my ride. Jeff
Late '99 down on power...
post #8 of 8 Old 12-14-2011, 02:59 AM
Hey Dave, are you talking about the Powertrain control module (PCM)or was it the F81Z-9E498-DA part you ordered?
How did you find the problem? Thanks Jeff
