leaking coolant
my truck is leaking coolant from the front of the motor. it is a steady drip, looks like it may be coming from the bottom of the water pump area. any ideas? leaking water pump/gasket maybe?
When the water pump bearing /seal go bad, coolant will leak from the weep hole. Its a sign you're fixing to lose a waterpump.
ok thanks, so i guess i should go ahead and get a new one and toss it on?
That would be what I would do. Shop around - you can get some pretty good prices at RockAuto and other places.
thanks.
i have a connection at a local ford dealer for parts, so i'll probably get it there |
