exhaust leak?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-11-2010, 12:30 PM Thread Starter
simone0414's Avatar
exhaust leak??
You can only notice it when you are in the cab. With the engine running & standing out side truck sounds as it should. Pop the hood & you can hear the noise a bit in the air filter which is a an aftermarket Air Raid. Noise is definetely on the drivers side & is only really noticeable when idling or coasting. When you come on the her a bit sound goes away. Trucks starts good, runs good, same power, runs like it always did. Just loud in the cab. Kind of sounds like my old v6 f-150 I had that had a bad exhaust manifold gasket. I have done a quick look & see no exhaust leaks.
Anyone have this problem?? Any suggestions?
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 3 Old 04-11-2010, 02:23 PM
Look for a soot trail - if not at the head/exhaust manifold interface, then at the exhaust manifold/up-pipe interface or the up-pipe / turbo interface. You may have to get a mirror and flashlight to do that last one. You could also temporarily plug the exhaust pipe with a rag for a very short interval while you listened - it may get loud enough to find.
dray8165 is offline
post #3 of 3 Old 04-15-2010, 01:31 PM
Check the ccv. I just thaught I had a leak there too and the damn tube wasnt plugeed into the air tube. Drivers side valve cover towards the rear there should be a hose with a 90 degree bend in it that plugs into the air intake.
Terry
2001 F350 crewcab Lariat 7.3L 4wd longbox
AirRaid CAI with AEM dry filter.
My truck towing my buddies broke down chevy
yotionblade is offline
