7.3 Slow to Start
It seems like I have to spin my motor longer before if fires than most others. Any ideas what may cause this??
Low cranking speed, low high pressure oil rail pressure (from leaking injector o-rings), ICP getting weak, IPR getting weak and/or leaking, low fuel pressure - any of these could cause your problem.
Gig'em back at ya - Class of '87 |
Thanks Dray!
How many of these potential culprits could be detected by a diagnostics test?? |
If you have access to a good scanner, like AutoEnginuity, you can record all of the parameters except fuel pressure (its not monitored)
Otherwise, try to eliminate them one by one. Jump the vehicle from another strong batteried vehicle to test cranking speed. Then, unplug your ICP and try again - the PCM will use a default value. Run through and check your glow plug system using this technique: Hard/No Start? Check here first. - Diesel Forum - TheDieselStop.com Make sure your HPOP reservoir isn't leaking down - check it in the morning before your first start attempt to make sure it still has oil - if its leaking down, the injector o-rings might be bad. Any smoke? Is it using oil? If none of these work, you might need to rent a fuel pressure gauge - you tap into the fuel filter assembly using one of the two plugs on the back. |
probably something simple. battery battey cABLE OR STARTER oops caps
Mine is doing the same thing.
I have auto ingenuity but need to get it loaded on my new laptop as the old one quit me. Can you tell me what parameters I need to put in to see which is the problem? |
Set up AE to monitor ICP and IPR duty cycle and crank it over. When you first turn the key on, you should get 14% IPR, and when you crank it, ICP should come up to 500 psi plus and IPR should be probably no higher than 25% or so. If IPR goes above 35% then you may have Injector o-ring leakage. That would explain the long crank times. You may also want to check cranking RPM, which should be a minimum of 100. |
I will check it out. |
I have loaded my autoenginuity program onto my new laptop and it connects to the truck but will not do anything except check codes.
(the truck does not have any) It will not let me select enhanced powertrain or pretty much anything else. Anyone know if the software is protected or some thing? I bought it several years ago and loaded it onto the laptop but it is history now. |
Sure it's protected......
You've either got to find the numeric key or purchase a new license I'd think (call 'em maybe they can help) |
