Valve cover leak?
02 7.3 114000mi. Ichecked the valley no oil. O n right rear the oil appears to be leaking from the bottom of valve cover down the block and on the oil pan. Is this common for a 7.3 with this many miles or could it perhaps coming from another source. If it is in fact the valve cover what can Iexpect to pay to get it repaired and should I replace both. I used to do alot of small repairs on my vehicles but those days are behind me now.
A more likely source would be the high pressure oil rail end plug - an o-ring change and you're done. The valve cover gaskets almost never leak.
checked HPOP clean as a whistle. the oil is running down the right rear of the block starting by the vavle cover. no oil puddling in the valley.
MarkTX - watch this video: I think your problem is the plug he shows at time 4:29
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners I understand your HPOP is not the source. I am talking about a drain plug that is in the end of the head - right below the valve cover in the back of the engine. You'll see it in the video - it makes more sense then. |
dray, definitely looks like that may be the culprit as there is oilresidue all around that area even the top. that would explain none in the valley as it would droll right out. that fella really seems to know what he is talking about. I'll take better look at it. Thanks abunch.
Yeah - when I got my PSD, I watched every one of his videos. Made me glad I got the 7.3 and not the 6.0. Good luck with it.
dray, Icrawled under and was able to see what I,m quite sure was the plug on oil galley onthe end of the head. Clean. Under the turbo quite oily which leaves me to beleive it may bethe turbo pedestal. What do you think?
Subscribed...
Replacement O-rings for Ford Diesel Engines |
subscribed... ?
