OIL LEAK HELP - Ford Powerstroke Diesel Forum
post #1 of 24 Old 04-06-2010, 08:27 AM Thread Starter
Nally7.3Powerstroke's Avatar
OIL LEAK HELP
So it thought I blew my hpop o rings out again because I found oil towards the front of the valley. But after checking the fittings they appeared to be bone dry, so now I am lost as to what the problem could be. The oil mostly drips on the starter side of the engine down the oil pan. I need some help from you guys who have had similar problems. Anything would be great, thanks.
Nally7.3Powerstroke is offline
post #2 of 24 Old 04-06-2010, 08:53 AM Thread Starter
BUMP..............
post #3 of 24 Old 04-06-2010, 09:06 AM
Tony V's Avatar
You sure that wasnt old oil up front? I cant help a whole lot cuase im chasing a similar oil leak myself.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #4 of 24 Old 04-06-2010, 06:42 PM
weird... i mean my whole valley was full of oil even from the turbo pedestal oring. my ebpv rod leaks now. pos... check all that stuff out.
Dietoremain is offline
post #5 of 24 Old 04-08-2010, 07:17 PM Thread Starter
So, I decided im going to have to pull the turbo off to check for all posibilities back there. Looks like this saturday Im going to have a little project going on. Hopefully I can get it apart relatively easy with no problems, knock on wood, lol. Will feed you guys in with anything I find and if anyone has some tips as to what to look for it would be greatly appreciated!!
post #6 of 24 Old 04-15-2010, 03:37 PM Thread Starter
Well I never got to pull the turbo because it rained over the weekend I was going to do it... so I got out of school early tonight and came home and decided to check the truck out. I cleaned the valley so it was spotless of oil so I could see if the oil up there was old or not, and come to find out tonight a puddle has formed again right behind the HPOP. Are there any cases where the pump itself leaks rather then the pressure lines? Because to me the pressure lines and end plug look dry with no residue. I am just starting to get confused at this point as to what the problem could be.
post #7 of 24 Old 04-16-2010, 05:55 AM
if its by the hpop then its an oring. Get a flashlight and a mirror and check the plug that faces the cab of the motor and the plug underneath the so called non servicable plug. With the truck running you should be able to see oil leaking out somewhere from one of those places. Mine was from the plug itself.
\Here is a pdf i found for ya.
http://www.thedieselstop.com/faq/949...les/040404.pdf
Terry
2001 F350 crewcab Lariat 7.3L 4wd longbox
AirRaid CAI with AEM dry filter.
My truck towing my buddies broke down chevy
yotionblade is offline
post #8 of 24 Old 04-16-2010, 07:57 AM Thread Starter
I checked the end plug and both pressure lines and there is no oil coming out anywhere around them...
post #9 of 24 Old 04-16-2010, 08:14 AM
There is also a gasket where the HPOP mates to the block. Maybe you should get the complete gasket set from dieselorings.com and just replace everything while you've got it off.
dray8165 is offline
post #10 of 24 Old 04-16-2010, 08:22 AM Thread Starter
I think it might be the gasket your talking about. Im pulling the truck apart now so I will keep you all posted on anything I come across.
