Eating ALOT of oil - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-03-2010, 04:10 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Eating ALOT of oil
OK, My truck has this issue with eating oil lately. I took a trip to Charlotte and back, probably 300 miles round trip last weekend. Went to start it today(havent driven it all week) and it wont move. Checked the oil level, and I am not even reading on the stick. A gallon and a half later, i am refilled.
There are no leaks that I can find. valley is dry, and no oil spots on the driveway. The truck isnt smoking when at idle, so its not giving me the impression that the turbo seals are bad. I just dont understand where the oil is going.
Had the rings and bearings replaced in motor 2 years ago, I dont think its from that. Any ideas?? Im stumped!
Heres another for you deep minded techies.....
When the truck sits for over a day, it takes some serious cranking time to fire. the HPOP is good, but the resivior seems to leak down. I checked the check valve right behind the HPOP, and its seating good. Was told it could be front cover, how does that affect it not starting?
Once its started and runs down the road a couple of miles, it starts up instantly the rest of the day. Only does it when it sits overnight or two. did notice that when nose is pointed in a slight downhill position, it fires up easier and with less cranking, but not like it should.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 6 Old 04-03-2010, 04:17 PM
Sounds like you have one or more leaking lower injector o-rings. The oil from the high pressure oil rails gets pushed into the fuel rail and it gets burned. Diesels actually burn oil pretty efficiently - some of the guys with the old IDI's burn straight used motor oil.
If your lower injector o-ring leak is sufficeint, it will back oil up into the fuel filter assembly, so you can pull your filter and look for contamination. If it is just a minor leak, sometimes it doesn't make it all the way back. Kind of a test where if it's in the filter you know for sure, but if it isn't you still can't rule it out.
dray8165 is offline
post #3 of 6 Old 04-03-2010, 06:46 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
so, if I pulled the filter in the fuel bowl, and it was dark, that would lead to the injector O rings letting the oil run into the fuel system? I did notice the fuel was awfully dark in the fuel bowl. I thought nothing of it really, other than a dirty fuel filter. guess I need to start pulling injectors. dangit. They have been in the engine just shy of 2 years....
Nick
"The Mistress"
post #4 of 6 Old 04-03-2010, 06:50 PM
choupique108's Avatar
Is there any oil in the antifreeze?
My dad had a truck that electrolysis ate it up and the oil got in the coolant
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #5 of 6 Old 04-03-2010, 06:51 PM
OregonStroker's Avatar
That sucks man but at least you had someone help you figure it out fairly quick.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #6 of 6 Old 04-03-2010, 06:55 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
no oil in the coolant.
Nick
"The Mistress"
