truck quit running and wont restart - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-31-2010, 12:20 PM Thread Starter
snowmobiler7c's Avatar
I have a 2003 7.3L 4x4 cc truck with less than 130k. I was cruising down I75 at 80mph today and all of a sudden it was like the truck was misfiring and had a loss of power. I tried pressing down on the pedal and it did nothing at all, so i just let it coast until about 15-20mph when the truck completely stalled out. Once i finally coasted to a stop it wouldnt restart, even now that its had 4 hours to cool down it still wont start. I have a feeling its a fuel issue or maybe the camshaft sensor?? any ideas? I replaced the fuel filter maybe 1500miles ago(id have to look to be sure) and the dealer replaced the camshaft sensor back in november under recall. The check engine light was on until i turned the truck completely off so hopefully a code will still appear even though the check engine light isnt on anymore. Any ideas or info would be greatly appreciated thanks'
mark
snowmobiler7c is offline
post #2 of 14 Old 03-31-2010, 12:38 PM
Scan for codes. Could be IDM as what you have described sounds exactly like what happened to me.
2001 F350 CC SWB 6spd......currently getting a complete makeover.
LOOSEWHEEL is offline
post #3 of 14 Old 03-31-2010, 12:42 PM Thread Starter
ok im going to try and get my buddys scanner whats the IDM?
post #4 of 14 Old 03-31-2010, 02:25 PM Thread Starter
got the scanner and no codes show up at all. Does it make a differance the RPM guage is not turning at all??
post #5 of 14 Old 03-31-2010, 02:38 PM
frank diesel's Avatar
(injection drive module) mine did the same thing started missing and finally quit wouldn restart it should be mounted on the driver side fender near fire wall black box with one 20 os so pin plug with a 10mm bolt holdin the plug in
frank diesel is offline
post #6 of 14 Old 03-31-2010, 02:40 PM
can you get the injectors to do a click test with the scanner ?? if the idm is not powering up it will not send current to the injectors check fuses and relays sounds lik idm imo
post #7 of 14 Old 03-31-2010, 05:23 PM Thread Starter
fuses look fine but is there any way to check the relays in the fuse box that go to the idm? how can you tell if those are good or bad?. is there any other way to test the idm? The scanner i had i dont think can test anything just pull codes.
post #8 of 14 Old 04-02-2010, 06:29 PM Thread Starter
if the imm is bad would i get a code??
post #9 of 14 Old 04-02-2010, 06:45 PM
Austinj427's Avatar
Try swapping out a CPS. They are too well known for going bad even when new.
Austinj427 is offline
post #10 of 14 Old 04-03-2010, 07:12 PM
Sounds like it may be the electric fuil pump ,its under the truck ,under the driver check it you should here run when you tune the key on , also you can remove the fuel fitter bowl top ,then tune the key on look inside two see if the pump is working good luck
snook2020 is offline
