colant temp sensor(s) 2002 F350. Are there 1 or 2? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-28-2010, 11:14 AM Thread Starter
jkoz10's Avatar
Are there one or two coolant sensors? I know there's an oil temp sensor also.
I was told one is for the gauge and one is for the computer.
Is that true and if so where is the second one hiding?
I found one right next to the upper radiator hose that points up. When I disconnect this I can see it on the gauge.
jkoz10 is offline
post #2 of 3 Old 03-28-2010, 11:19 AM
CSIPSD's Avatar
The water temp gauge on a auto is nothing more then a switch. The PCM has no idea what the water temp is.
There is only one sender.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 03-28-2010, 11:26 AM Thread Starter
jkoz10's Avatar
OK - that's what I thought, just wanted to double check.
The ecm uses the oil temp to make changes then.
jkoz10 is offline
