Cranking issue... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-26-2010, 04:53 AM Thread Starter
the witchdoctor's Avatar
Cranking issue...
Sometimes I will get in my truck, and it won't do anything... let it sit for a few minutes and then it cranks... intially won't turn over or anything... could this be the gpr????? Also, my truck has 2 relays, are they both gpr or something different.??????
THE WITCHDOCTOR
(sold) 2001 F250 xcab 4x4,Steel cowl hood, Leveling Kit, S&B, Eagle 18x10,285/70/17 Kelly TSR's,A/C Mod, Isspro EV2's, Foil Delete,Banks Big Head, TS 6 pos chip/Tyrant Tunes,BTS valve body,Stancor Mod, 4" exhaust
the witchdoctor is offline
post #2 of 8 Old 03-26-2010, 06:44 AM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
I'm pretty sure what you're dealing with here is Voodoo
OK, so no, the GPR relay can't effect the starter engaging (the second relay up there is for a heater in the intake). I don't know what just "letting it sit" could do for you other than just being an intermittent problems cure....
You have to dig farther and follow the flow of events that should happen when you turn the key (anything from the starter itself - kew sw - relay - Neutral Safety sw - even the batteries)
Does it crank at a good speed once it starts?
Do you hear any "clicking" even thought it doesn't crank?
Tried putting it in "N" instead of "P"?
Tried hitting the starter motor with a hammer a couple of times when it does it?
You need to do some more investigation....
NoRalPh is online now
post #3 of 8 Old 03-26-2010, 07:41 AM Thread Starter
Man I knew I shouldn't have did that voodoo doll that looked like my truck!!!! It does crank great when it spins over... as far as a click, I faintly hear one like under the dash. I have tried it in neutral, same result. As far as tapping starter, haven't had to yet....
THE WITCHDOCTOR
post #4 of 8 Old 03-26-2010, 08:58 AM
Quoted: 177 Post(s)
If you get a test light connected to the starter itself you could see if it's getting 12v when your turn the key to "crank". If not back-up to the relay and see if it's seeing 12v coming from the key then. OR it is not "throwing" when it does....
You might have to jump-out a bad Neutral Safety Sw.
Like I said, follow the flow of what's supposed to happen
post #5 of 8 Old 03-26-2010, 11:19 AM Thread Starter
will do... hoping maybe for a bad starter relay
THE WITCHDOCTOR
post #6 of 8 Old 04-15-2010, 01:03 AM
4banger's Avatar
sounds like a battery cable issue
2001 F350 CC SB XLT - 6637 w/ Petes filter cover, 08 white tailgate mod, 08 windshield, Gentex Temp/Compass Mirror, 03 Heated Signal Mirrors, Tail light guards, BFG A/Ts
316,000km's
4banger is offline
post #7 of 8 Old 04-17-2010, 01:42 PM
ol'white027.3's Avatar
im having problems with a starter relay or igintion switch when i go to start my truck SOMETIMES it does nothing, the lights in the dash just go off like it would when the trucks starts normally no clicking or nuthing so i jump across the soleniod on the starter and itll start so wat im askin is were is the starter relay or fuses for the starter and also my truck only has one starter solenoid which is on the starter itself ive seen 7.3 with 2 with one on the pass side behind the battery on the fender well is that normal should i just put a push button start on it or is that more work than replacing the relay or the fuses
edge evo.
4" turbo back
gauges fuel pressure, boost
tw custom tuned 6pos chip
twisted diesel level 2 tranny
afe cold air intake
boost fooler
cant forget the train horn
ol'white027.3 is offline
post #8 of 8 Old 04-17-2010, 02:06 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Thats what I was thinking or a corroded connection on the starter or starter relay
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
