hpop leak wont go away! - Ford Powerstroke Diesel Forum
Old 03-22-2010, 02:05 PM
alright i have a 99 7.3 i noticed its was leaking from the plug in the back of the hpop ive changed the o-ring with a "Viton" oring which is for high heat and oil and put a liquid thread sealant on the threads which works great for like 15 min then it starts leaking pretty bad from the o-ring? i didnt over tighten it and tear the oring so i have no idea why this keeps happening any help?
Old 03-22-2010, 02:26 PM
Which plug are we talking about?
Old 03-22-2010, 02:30 PM
the plug labeled plug
Old 03-23-2010, 08:48 AM
well after blowing out another o-ring last night i decided to try a copper washer seams to be working no leaks
Old 03-23-2010, 09:33 AM
That is strange. Where did you find your orings at? Are you sure they are the right size?
Old 03-23-2010, 06:34 PM
That plug should take a #906 ORB o-ring.
If it still leaks, something strange is happening, like a twisted o-ring when its installed, or perhaps a ding or scratch in the o-ring land, causing it to leak by
