Glow Plug Control Module or Glow Plug Relay?
So I'm working on this guys 1999 7.3 an the problem is that it won't start below 40 degrees without it being plugged in, I checked the fuel pressure, and filters, I've checked the air filter, and I've check oil level, so next, which I know I should have checked the relay and the module first, but the guy wanted the all the filters changed. So where is the module and relay an how to check
the gp soliniod is behind the fule filter and to the left on the top of the motor, looks like the starter solinoid, thats all i could help you with im just learning these powerstrokes myself
I think these are supposed to hold 12v for at least 30 sec when key is turned on
Any one have a clue where the glow plug control module is
So idk if this is right or not but the glow plug control module is only on the 6.0 and 6.4
The module would be in the same place - You only have a glow plug control module on Excursions and California emmision trucks. You have a glow plug relay on all other trucks. Its a one or the other, not both kind of thing.
Read here about how to check out your GPR system: Hard/No Start? Check here first. - Diesel Forum - TheDieselStop.com |
