99 wont crank at all, fuse position - Ford Powerstroke Diesel Forum
Old 03-16-2010, 08:05 PM
Ok just started to look into this this evening didnt get very far, I cant get the truck to even crank over or even click. I think it might be a fuse or relay, i dont have a book to tell me the position of the fuses, anyone have any idea what they are or what could cause this problem? any ideas or awnsers would be great!
Old 03-16-2010, 10:30 PM
Any fuses blown ? If so what number fuse. Your truck auto or standard trans?
Old 03-16-2010, 11:47 PM
You can dl the owners manual at. https://www.fleet.ford.com/maintenan...ls/default.asp
It will tell you info about fuses and relays. But I would check them and replace all that are no good.
Old 03-17-2010, 05:26 AM
thanks for the link on the manual thats what im needing
Old 03-17-2010, 10:30 AM
No problem.
Old 03-17-2010, 06:21 PM
checked all fuses that are for the ignition and they are good any more ideas? mabye check starter solinoid
Old 03-19-2010, 09:14 PM
ok all fuse are a go, replaced the starter solinoid and the ignition switch, thinking it might be the nuteral safety switch poss?
