Cant figure out dtc
All right my dumba$$ ran outta fuel tonight on the way to the diesel station. Called roadside service, made it to the fuel station filled up then my check engine light came on. I checked the codes and came up with 6 DTC's. I was able to find 5 of them. The one that stumped me was P1249. 2 of the codes deal with the ABS but I knew about that, 1 was P0238 which is turbo boost sensor A circut low (dont know what that means) next is P0344 which is camshaft position sensor circut intermittent (I know what this means). Last is P0470 Exhaust pressure sensor malfunction (dont know what that means). Now for my question, will running out of fuel cause air in the lines and make all these codes come up or am I gonna have to pay for a bunch of sensors. Maybe Marc will chime in and let me know what all the ones I dont know mean.
running out of fuel can cause all kinds of strange codes in these man......here is the 1249
P1249 Waste gate steady state failure GND short, plugged hose/port, solenoid, actuator if i was you i would disconnect your battery cables for a while today and get rid of those codes and then see if any come back.......Marc |
I agree totally with Marc. I chase my youngest around with a fuel can all the time. We use the programer to clear the codes. Most of the time the Superduty will clear itself after a few run cycles. My Excursion won't. If I get happy with the HP I can set all the bells and whistles off. They shure chug hard when there pushing out the air!
Yeah for real, there's been times that i've been running for a long, long time on the low fuel light....luckily i've managed to avoid this situation you're describing!
Yeah I test drove an 03 cobra one time and practically coasted into the lot at the dealer. I wasn't puttin gas in it on my dime!
lil red.....go get on the hiway and run the heck out of it.......get all that air worked out of those lines and that should cure the hesitation.......Marc
Thats kinda what I hoped. I cleared the codes and havent had the light come on as of yet. I've had the baby with me for the past couple of days and haven't really had a chance to get on it too much. But on the way to work tommarrow I will definatly have more than enough time to stay in it.
