Injector Problem
Ive been having some white/blue smoke under heavy throttle lately, it use to be just at low rpm 900-1100. When it would happen between 900-1100 rpm the truck would shake "miss", I think I have narrowed it down to the #8 injector. If I look at my cylinder rotaionnal values with A.E. the #8 is seeing 3-4%, while the other 7 never see more then 1% usually they stay at 0%. Also this is an intermediate problem, sometimes my truck runs great, others times not. A change in outside temp seems to make a differance, lately in CT it could be below freezing or up to 70deg. It seems to act up the most when the temp changes.
Is this just more on start up, or are you up to operating temps? If it is on start up, it maybe a bad glow plug relay, or glow plug. Just a thought.
Not at start up, just while running. It is intermediate so it happens cold and/or up to normal running temp.
