Engine miss? Bad valve cover harness?
my truck has an engine miss for the first few miles when the engine is cold. You mainly feel it in the higher gears. I know this is gonna sound crazy but the only way to get it to go away is to floor and you can feel the truck have more power once it clears up also once it clears up it will be fine until the engine cools off again. it also seems like the trans shifts a lil funny when its missing. the ses light is not on it has a new cps, new map sensor. it has been like this for a couple months the cyl cont test showed cyl 3 & 8 bad so i changed injectors in 3&8 but it still shows 3 bad. Could this possibly be a bad under valve cover harness?
Update i put a new valve cover gasket and harness on pass side today and its still doin same thing.
How cold is it where you are? The glow plugs stay engaged for a little while after the engine starts - if you had a couple or more glow plugs out, it would take longer for those cylinders to come to life...
Run a compression test.
same issues see my thread need help rough idle no power until very warm, haven't figured it out but hpo crossover seemed to help mine, and fixing up pipes leaks, i'm thinking ipr or injectors on mine. good luck
not a glow plug issue a ford tech told me today it could be my idm?
Every figure it out?
have you tried the valve cover harness plugs? both sides inner and outside? that was my answer to my wild goose chase. good luck
Hey I have the same issue. #3 and #8 did you recently get the cps recall done? i took mine to the stealership to get a glow plug relay replaced and they took out my black cps and put in a new gray one. truck ran alright for a day... next morning SES is on. I then took it back they tell me #3 and #8 injector are toast and I need new UVCH's I get #8 injector done like an idiot. then get it back it runs worse than ever, tired of being taken by the dealer I take it to an independent that is highly regarded by a local forum. They tell me my #8 isnt fixed right by the dealer and want to do #3 injector as well. I authorize work that day they give back to me telling me it is fixed. next day SES is back on. I take it back down there they flash the PCM and tell me it is good. Truck ran great for about 80 miles then SES is back. Here I am today, generally when the cps light is on it feels like it is missing from 1200-1800 rpm, and if i get on it goes strong and smooth. I just bought and AutoEnginuity and a "Black CPS" should be here by the end of the week, so tired of throwing money at this truck
I have found countless other threads on how for some of these trucks the gray CPS they are putting for the recall is causing misses and failing CCT for #3 and #8. I am just getting started with my battle with wondries ford of montebello to try and recoup most of the 2500 i have spent due to what i am very close to believing is this damn gray CPS that I never even authorized. Hope this helps and I can relate :-\ |
I burned up my valve cover gasket wiring harness, internal connections. CEL light on and no codes, running real rough and no power
