glow plugs flakin out on me - Ford Powerstroke Diesel Forum
Old 04-18-2007, 06:28 AM
so every once and a while ill turn the key and the glow plug light will be very dimly lit and i can hear a solenoid somewhere freakin out...like tdtdtdtdtdtd...lol, the glow plugs are not workin at this time. any had this before? bad connection? bad solenoid?
Old 04-18-2007, 07:02 AM
The WTS light on the dash is controlled by the PCM not the GPR or the GP's themselves. It sounds to me to be more of a power problem than a GP system problem.
How does the truck start? What voltage do you have on the batteries when cranking?
Old 04-18-2007, 08:10 AM
ADMIN AND TECH
two things that come to mind that ive seen over the years are one - moisture in pcm on that model and also they had some problems with the actual fuse panel under the dash seperating internally causing power loss to several components , loss of ground , etc. relays clicking fast usually means ground loss, may not be your problem just my two cents
Old 04-18-2007, 09:16 AM
i havnt checked the voltage on the batteries yet while cranking.....but while its acting up it acts just like no glow plugs...cranks real good but wont fire up.... this problem just started a couple days ago and its not very bad.....yet....
Old 04-18-2007, 10:45 AM
Check the voltage with a digital voltmeter while someone turns it over. It needs at least 10.5 volts. If less than that, remove and clean your terminal posts and charge the batteries. If it is still less than 10.5v, have the batteries load tested. If one is bad, replace them both. A weak battery will bring a new one down to its level and shorten its life.
These trucks will crank real good with less than 10.5 volts but it's not enough to allow the IDM to fire the injectors.
If the voltage is good, then check what SCUFFY said. Your windshield may be leaking and dripping on the fusebox or PCM.
Old 04-18-2007, 12:16 PM
i did get my windshield changed not too long ago...a few months
Old 04-18-2007, 01:01 PM
ADMIN AND TECH
the pcm is not to hard to pul out ,take it out and pull the cover off of it and see if wet inside , that sounds like your problem to me , pcm is probably not hurt if problem is intermittent but beter get it fixed
Old 04-19-2007, 05:07 AM
hey thanks i better do that... we are getting rain off and on this week in SLC so that could be related. where is it? whats it look like?
Old 04-19-2007, 05:30 AM
The first two pictures will give you a good idea of how to remove the PCM
Welcome to guzzle's DP Tuner's Chip Installation Web Page
