Turbo o-rings leaks - Ford Powerstroke Diesel Forum
Old 03-01-2010, 12:49 PM
Exclamation Turbo o-rings leaks
Do turbo pedestal leaks tend to get worst over time? I have a leak towards the rear of the motor (valley by HPOP is dry) which drips down the bellhousing, then over to the oil pan. The leak seems to be small one though (no pooling of oil on the ground). I was just wondering if it's necessary to change them out ASAP.
It's a pain trying to figure out where the leak is coming from back there unless you start pulling hard parts.
--Ryan
Old 03-01-2010, 12:57 PM
I'd be interested in what you find...I'm getting the same thing....leak down below (mine does drop 'some' on the driveway, but not BAD), no valley puddles. If I can get some time & it will quit raining long enough, I need to crawl up under the hood look too.
You and I have the same truck, except for the color.
Old 03-03-2010, 03:33 PM
Mines leaking to but wont be after this weekend im picking up the o rings from ford tomorrow 4 of them $13
Old 03-03-2010, 03:47 PM
Mines been leaking, but I've changed my turbo o rings twice. Its leaking somewhere in the back due to around hpop area is dry as well. is there anything else back there that can leak?
Old 03-03-2010, 04:16 PM
Yeah I wish i knew where mine was..
Old 03-06-2010, 07:37 AM
Did you change out all 4? 2 below the pedestal and 2 beneath the turbo?
Old 03-06-2010, 10:19 AM
Yeah i've changed all 4.
