SES light,P1316,P0470,P0478 - Ford Powerstroke Diesel Forum
Old 02-28-2010, 11:37 AM
First thread here!2000 F250 7.3 4x4 auto. Truck has benn running fine until yesterday morning, started up fine then started missing w/SES light on.went to local parts house to scan and no codes. Went out and bought a DS tuner and got p1316,0470,0478 codes.Removed both valve covers and started pulling inj. wires off with it running and found one inj. that didn't change the sound of engine rpm and replaced it.Put on one new valve cover harness and thought it would be fixed.WRONG. Still right where I started.I also did Guzzel's fix for EBP valve but didn't replace sensor,dealer closed on sunday, Thanks Guzzel ! Please Help me.
Old 02-28-2010, 12:31 PM
Engine has 179,00 miles,stock,305/70-R16 BFG AT's,air box mod,glow plug relay light in dash to monitor status.
Old 02-28-2010, 12:40 PM
duct tape & zip ties
P1316 is injector drive module codes detected. P0470 is Exhaust pressure sensor, P0478 exhaust pressure control valve high.
You might have a bad injector drive module. Which could be causing your engine running rough. The codes could be a result from how your engine is running.
I would do more diagnostic to the truck before replacing stuff.
Old 02-28-2010, 12:56 PM
Thanks Big Country .Is there a way to test the IDM at home?
Old 02-28-2010, 12:59 PM
I do not know, you would have to ask a tech about that.
Old 02-28-2010, 01:43 PM
Anyone else have an idea what it could be? Someone surely has had this problem.What fixed yours?Any comments welcome.Any techs here today?
Old 03-01-2010, 06:10 PM
Found a good and easy way to diagnose code P1316.I had a bad Injector #6 and a bad UVC harness,the bad harness was a brand new one,put old one back on.Troubleshoot using this link and maybe you wont have to do it twice!..P.S. you can check the injectors by puliing leads off one at a time carefully. 110 volts.I used sparkplug boot pliers.
http://www.gbreman.com/docs/techbull...eplacement.pdf
