oil over full/ diesel fuel mix?
A week or so ok, my truck acted like it had an injector stick. Today I go to check oil and it was what I woul dguess at 3 quarts or nore over with deisel mixed in... i have drained and keeping an eye on it.... 03 f250 super duty 7.3 |
hmmmmm. Are you sure its not coolant?
Pretty sure. It did float on top when I drained the oil...
I doubt it is diesel - it would mix with the oil since both are hydrocarbons. Water can get into your oil with a bad oil cooler. Here is a source of the rebuild kit with a .pdf instruction page:
Replacement O-rings for Ford Diesel Engines Oil can get into the diesel with a bad lower injector o-ring, normally noticed by blue smoke and observing oil discoloration in your fuel filter. You could probably tell what it is with a match - diesel burns slowly - water doesn't burn at all... Maybe dip a stick in the suspect fluid and light er up... |
Thanks Guys! I meant to type it DIDN'T float...lol.... I suspect it is diesel.. gonna keep my eye on it for a couple of days and then see where to go from there..... I assume this is a pretty common issue with these motors?
It is not real common, but is is real dangerous. Diesel will dilute your oil and if you run it mixed, you'll end up tearing up a bearing. I wouldn't drive it until I knew where the diesel was coming from. These motors are just too expensive to rebuild / replace to risk it.
Thanks! First diesel I have ever had, have race cars and such.... I am hoping it was from where it acted up one day last week like it was misfiring an injector and loaded the cylinder up.... hopefully! Will let you know when I find out.
Did you ever find out? I think I have the same problem......was 2 qts over filled and after 150 miles it was higher again.
