Blue smoke - Ford Powerstroke Diesel Forum
Old 02-21-2010, 05:58 PM
Blue smoke
Well everytime i start my truck when its cold it will just dump blue smoke everywere. Like it is running on straight oil. but once it gets hot i only get blue smoke at like 2600 for a second. the oil level hasnt dropped significantly in the 400 miles that ive had the truck. any thoughts?
Old 02-22-2010, 07:05 AM
Blue smoke does generally mean oil. I think the easiest test would be to pull your fuel filter and look for traces of oil. That could mean your lower injector o-rings are leaking. Valve guide seals leaking could cause oil burning, but more in gasser motors (because of the vacuum) and usually only at startup.
