WATER IN FUEL LIGHT - Ford Powerstroke Diesel Forum
Old 02-21-2010, 03:11 PM
WATER IN FUEL LIGHT
I just purchased my 2000 7.3 F350 a few days ago. It has the water in fuel light on. I drained the separator with the yellow valve and changed the filter. Do I need to reset something to get it to clear or do I have a bad sensor?
Old 02-21-2010, 03:31 PM
Lightbulb
I had this happen to me and ended up being the 0-rings leaking ...
Replacement O-rings for Ford Diesel Engines
I keep a spare set now
Old 02-21-2010, 09:33 PM
mine came on today i shut the truck off and drained the water out started it back up and light is gone.
Old 02-22-2010, 06:39 AM
You might have a gunked up fuel filter assembly - Drain it again, take of the filter, and clean it up. Occasionally, they will get so bad that you have to take them off, dissasemble them, and clean them with brake fluid.
The crud in the bottom could be interfering with the sensor.
Old 02-22-2010, 01:04 PM
Water is fuel light
Thanks, The old filter was nasty and the housing was dirty. I will try to clean it up tomorrow. Where exactly is the sensor in the separator? Thanks for all the help!
Old 02-22-2010, 01:12 PM
If I am not mistaken, the fuel heater thermostat and water sensor are together, at the base of the bowl, in the back just beside the fuel drain assembly. There is on connector on the back of it.
Old 02-22-2010, 03:05 PM
Thanks, I will take a look at it tomorrow. Thanks
