Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 04-12-2007, 05:21 PM
klingerman73 klingerman73 is offline
ANY thoughts....major OIL drop
Hey there guys....
I have a 2000 f350 PS, driving it to work today, suddenly lost power and smoke started pouring out of the engine compartment. Pulled over and there was oil everywhere!! I checked the crankcase and it was empty. the oil was everywhere.
In any case it was just towed to the service station. I hate that I am not working on this, but I usually do not have all the tools needed to work on the engine.
ANY thoughts on what could have happened. I have had some people say the turbo went. Some say the oil pump....not sure where to begin besides giving the engine and the rest of the truck a bath.
Thanks for the help!!
klingerman73
Old 04-12-2007, 05:24 PM
mschn99 mschn99 is offline
Originally Posted by klingerman73 View Post
Hey there guys....
klingerman73
fill the crankcase back up and have someone crank the motor while you watch. Odds are your leak is from the high pressure oil pump, and it is just a matter of where on the pump is leaking. Its not real common, but occasionally we see one that blows the snap ring out of the back of the pump and causes just what you described...it would be worth checking.
Old 04-12-2007, 05:49 PM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Marc is SOOO smart!!!
Old 04-12-2007, 06:25 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
I was going to say hpop but marc beat me too it. I hate being late like that.
Old 04-12-2007, 07:15 PM
Thanks for the quick responses guys!!
Old 04-17-2007, 08:20 PM
HPOP Line....that was it
Well guys it was a HPOP line that sprung a leak.
I had the line replaced and it appears that things are working ok... The truck doesn't start as easy as it did before. I am assuming that air got into the line somewhere.
Anyone know if this will go away, or will it continue to be hard to start now?
Thanks again!
Old 04-17-2007, 08:22 PM
Thanks again!
go run it hard for about 10-15 miles and that should clear up.....
