dry HPOP resv??
ok..here we go again. Had scott(scuffy) do a bottom end rebuild(replaced pistons and rod bearings) and ended up with a hard start problem. Would crank like hellfire, catch then immediately die..crank, catch, die then finally stay running. Well, this evening, at the Flying J in Ft. Pierce, Fl, went to start her up and nothing but crank. Through a process of elimination, changed the CPS(had a good one)..no change. Checked fuel..plenty of fuel so that wasn't it. Then, just for schyts and giggles, I took the plug out of the HPOP resovior(ok..so I can't spell it..sue me..LOL) and lo and behold it was BONE DRY! Filled it up using a make shift paper funnel and waa la! after just a few cranks, the ol beastie fired right up! Any idea what would cause the resv to drain out over a few hours?(When she's running, she stays running and will fire up if I shut her down for just a short time). Also..no apparent oil leaks in the gallery or on the ground. I'll be calling Scott tomorrow, actually later this morning as I look at the clock.. for his input but since its now 1:22 in the morning and I'm wired on coffee, figured I'd give Ya'll a shout.
sounds like the anti drain back isnt anti drainbacking.
where might that be located? easy to get to and not a lot of bucks?
just saw your tag..gonna be near lakeland later this afternoon.
dunno yet for sure friday nights r always up in the air.
wat year is ur truck |
its an 03 E550(yeah, she's a beastie but what the hell, so was my ex-wife..lol) but the engine is late 99.
i dont think urs has antidrain back. i believe its only on 94-95 powerstrokes.
seems like u have a leak somwhere inside the motor tho that should keep that res full. |
that ain't what I wanted to hear..can't afford to pull this engine again.
but then again u might jus still be gettin the air out of it.. i know when i pulle the motor in my truck (all 3 times) it took it while to get the air out of it and crank like it should.
yeah.. but we put the sucker back together just over 2 weeks ago and she's been difficult to start at times ever since.
