NEED HELP: STARTER REMOVAL - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-07-2010, 01:19 PM Thread Starter
All,
Long story short: while trying to put my turbo back in I dropped a Marmon clamp bolt down the y-pipe. I'm trying to get it off so I can get the bolt out and the turbo back in. I've gotten all but one bolt out (passenger lower side); the starter is in the way. I've gotten the starter loose but it will not come out. All wires are off but it feels like a strap or something is holding it from comming out. I've twisted it and tried to pry it out, but nothing works. Have I missed anything or is it just difficult?
BTW: the truck is sitting in my garage and I've been working on my back; no lifts or ramps, making everything twice as hard. I've taken off the fender and liner. I'm really beginning to appreciate why Power Stroke techs charge so much.
F250 sold.
nc1500 is offline
post #2 of 3 Old 02-07-2010, 05:13 PM
simone0414's Avatar
I changed mine yesterday & it came out real easy. How many bolts did you take out where the starter bolts to the block? Mine had 2 bolts but there are some that have 3. Other then that I don't know what to say. Once I took the bolts out mine pretty much fell out.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #3 of 3 Old 02-13-2010, 02:47 AM Thread Starter
Three; as I said it's very loose and, as you said, should just fall out. Something is holding it from doing so. Not having a lift handy makes everything 10x more difficult. I have a local Ford tech coming out Monday morning to give me an estimate on putting the turbo back and, hopefully, give me some advice to fix this correctly next time.
F250 sold.
nc1500 is offline
