To much pressure in fuel bowl??? - Ford Powerstroke Diesel Forum
Old 01-31-2010, 05:11 PM
It is a 99 f550 I replaced the high pressure oil valve on the hpop. Truck will not start now... it will run on ether but that is all. Gauge on dash shows that it is building oil pressure when i crank. When I open the valve on the back of the fuel bowl it blows fuel hard onto the ground like there is to much pressure on the bowl. Any suggestions on either problem?
I think i need to replace the whole hpop it was acting up before i started working on the truck.
Old 01-31-2010, 06:36 PM
DONT USE ETHER/STARTING FLUID, its like a drug for a diesel engine once it gets a taste it will get addicted and not start with out it
Old 02-01-2010, 06:36 PM
I was just trying to get the air out of the lines by getting the engine running. I don't like using either!
Old 02-01-2010, 06:50 PM
There's probably just air in some of the lines, oil or fuel or both. Probably fuel if it runs on ether but not without it.
Just crank on it for a while and then let it sit. Then repeat. And keep going till it starts. Once it does keep it idling high.
If you DO run ether, disconnect your glow plugs. If you don't, it can cause early detonation and not do good things.
Old 02-02-2010, 05:19 PM
addicted to diesel
is there oil in the hpop. if not the injectors wont fire period.
Old 02-03-2010, 02:29 PM
Yea the hpop tank has oil in it. I beleive the the hpop has just gone bad, i have been having trouble out of it for awhile now.
