Strange Oil Leak
I have a 02 F250 that has developed an oil leak. It seems to be coming from under the hpop. Any suggestions??? Thanks.
There are some fittings under there with orings. My buddy actually had a leak just like this. He was able to fix it without removing any thing on the engine. Try looking along the sides with a flashlight for any wet spots.
Thanks. I will check that out.
the fitting on the pump leak, they sell o-ring kits to repair them
Gday from sunny Western Australia this is big Dom and I have a similar leak from the hpop but it is from the fitting under the hoses on the left hand side of the vehicle and I was wondering about the internals of the plug because all we found was a teflon ball and the pedestal plug with an o,ring is there any procedure to install this set up if removed and if there are any parts that can be purchased for the pump as in W.A the resources and tech info is near on non-existant even thru ford dealers
