fuel leak into valley - Ford Powerstroke Diesel Forum
Old 01-24-2010, 05:17 PM
I just purchased a late 99 7.3. I have some fuel leaking off the back of the motor while the truck is running. I have looked through several threads about fuel leaks, but most of them deal with 94-97 trucks. I have a stupid question, do the 99-03 7.3's have a pump in the valley, or is the only pump the one under the driver side of the cab?
I looked around the fuel filter area with a flashlight and could not pinpoint the leak, I will try cleaning it up and looking further tomorrow.
so far the list of possible leaks I have come up with are
-leak from o-rings at fuel bowl drain
-leak from a hole rubbed into one of the fuel feed lines to the heads
-o-ring on top of fuel filter leaking (dont think its that one)
What else should I look for? Will my dealer stock parts like the drain valve and the steel fuel lines?
Old 01-24-2010, 08:43 PM
drain on the fuel bowl.
Old 01-24-2010, 08:48 PM
If you do the drain on the bowl it is worth it to get the other kit and replace the o-rings in the fuel lines going in and out of the fuel bowl. I did mine at the same time and they looked terrible. No problems now.
Old 01-24-2010, 09:06 PM
its probably your lift pump there is a weep hole in the bottom and starts leak when it go's bad
Old 01-25-2010, 03:53 AM
please excuse my ignorance, but dont the 99-03 trucks have a pump under the cab and none in the valley? I couldnt see anything that I thought was a pump in the valley.
Old 01-25-2010, 03:59 AM
where might I find said o-rings? I hate to get overpriced stuff from the stealer, but I need to drive the truck on a pretty long trip this week, and I would like to get it fixed before that, so online orders probably wouldnt be here in time.
Old 01-25-2010, 08:30 AM
well I ordered a 9 peice viton o-ring set because it sounds like its a good idea to replace those anyways. I might also order a new drain valve just in case that ends up being cracked or something. I am going to remove the y-pipe and see if I can check out the steel fuel line that runs to the rear of the passenger side head.
So to confirm, 99-03 trucks do not have a mechanical lift pump in the valley right? just en electric pump under the truck?
Old 01-27-2010, 03:28 PM
fuel problem
Hello,
I resently purchased a 2002 and same issue,,,,,,fuel leak was filling up the valley and leaking to the back of the motor,,,,Found that the o-rings on the fuel lines themselfs were shot,,,,, Went to ford and bought a o-ring kit for $26.00,,,,Easy replacement ,,,,dont loose your head ,,,Acouple of things need to be removed from the right side of the filter housing to gain access but a easy repair,,,,,,,,,,,,,,,,,,Good Luck
Old 01-27-2010, 03:30 PM
Fuel Loss
I have an 02 superduty quad cab long bed and i used to get 600 miles out of my tank and just recently have found my truck eating up the fuel,,,,same driving conditions just now am loosing fuel,,,,suggestions on what to do or look for,,,,,,,,,
Thank You
Old 03-01-2010, 11:28 AM
i ended up removing the entire fuel bowl and replacing all the o-rings with viton orings, i also replaced the drain valve, all all 6 of the fuel line sleaves (those were looking pretty bad). I took the feed line off the passenger side head to see if it had rubbed through, it had not. I removed the sheet metal clip that secured it that is known for rubbing a hole. Fuel leaks seem to be gone. Not sure which was the worst culprit, but I do think it was leaking out of several of the locations.
