Rough Idle andvery slow acceleration [help]
motor starts and runs with rough idle and accellerates very slow in nuteral,no smoke , oil pressure needle is on n for normal I have replaced computer with no inprovements Any help would be great? 1994 PSD F-350
Have you tried the CPS?
You may also want to have a cyl. contribution test ran on it to check the injectors. Welcome to the Forum! |
Thanks for the welcome, havent tried the cps but I read other threads pertaining to the cps and will replace ? I read on this site that I can pull v-covers and stumble test each injector similar to plug wires is this correct. thanks for your responce
I read on here that someone dropped a injector while on the road. Of course no access to scan tool so he pulled the valve covers and unplugged the injectors just for a moment while truck was running to determine which one it was. Just my 2c..
