All right all, I am having some major issues with my powerstroke. 2000 7.3 auto
Throwing codes: P1211- ICP pressure uncontrollable, below/above desired P1209- Injection control system pressure peak fault P0603- KAM memory loss P0478- Excessive back pressure P0470- EBP sensor circuit malfunction P0344- CMP sensor circuit intermittent Please help, will only run for a minute or two then die, I reset DTC's with my super chips (which I only use to read codes), then fire it back up, does the same thing. Also have Edge Juice w/ ATT. At high RPMs doesnt seem to affect truck, then I get to low rpms and it dies. Jacob |
My 97 power doing exact same thing got codes 470,478,1209,1211,1249,1280,1316 I think we should start with the ipr but I by no means an expert hopefully someone here can help.
Not a diesel mechanic but, anytime I see a lot of codes, I'm looking for an eletrical problem. Ck batt voltage, high or low will set multiple codes. Ck batt cable connections.
Could be an electrical issue as said above. Check your grounds
DUH!!
Went out today to start my truck, and would only run for about 10 seconds, bought a code book from Schuck's and what do ya know, it was my little flippin $25 crankshaft position sensor. I felt like an idiot!
![]() Thanks for all of your help guys!!! |
Yep always go with the cam sensor code first.
Are you in Jerome, Arizona?
