Injector cups? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-18-2010, 06:27 PM Thread Starter
Injector cups?
My 2001 250 started rough this afternoon and died 20 seconds later. The coolant tank has diesel in it.
My guess is a leaking injector cup flooded a cylinder while the truck was parked.
Is there anything else it could possibly be? The diesel in the tank is very new so I'm 99% sure it's related. I don't see how a head gasket could cause diesel to get into the coolant, but I don't know much about these engines.
_____________________________________________
[LEFT]For business:
01 PSD CC 4x4 F-250
Power everything
Leather seats
For pleasure:
04 YFZ-450, WR Crank, 13.5:1 piston, Ron Woods Racing head, Crower cams, Programable ignition, Jet kit, Fuel/K/N intake, Ron Woods exhaust, Hinson clutch, worn out 06 suspension, more.
Tyler325 is offline
post #2 of 3 Old 01-19-2010, 10:23 AM Thread Starter
Just to add, I spoke with my local International dealer and they cannot find part 1814376C1 in stock anywhere. Is this the correct number for the cups/sleeves/tubes/whatever?
Also, this all happened very quickly. Is it possible that a crack or gasket somewhere else in the engine could cause diesel to enter the coolant at a high pressure?
I'm really not to excited about this, but I plan to at least get an inside look at the cups as soon as I can make space in my shop (oil well tools) and get my truck towed over here.
[LEFT]For business:
01 PSD CC 4x4 F-250
Power everything
Leather seats
For pleasure:
Tyler325 is offline
post #3 of 3 Old 01-27-2010, 07:30 AM
i believe the only way for fuel to get into the cooling system is a bad injector cup/sleeve. i also own a '01 and just put in all 8 cups.my truck was getting fuel in the cooling system and over filling the over flow tank. i tore it down and tried to pressurize the cooling system to find out which cup was bad but,after holding 16 psi over night i decided to replace them all.i bought the "whitaker tools" removal & install tools and all i can say is they work GREAT!!! 1/2 an hour to pull the cups (all 8 after tear down) and less time to tap in the new cups.shoot me a PM if you need any help.
tipsyjack is offline
