Vibration at low rpms...I'm lost! - Ford Powerstroke Diesel Forum
post #1 of 24 Old 01-16-2010, 07:24 PM Thread Starter
Question Vibration at low rpms...I'm lost!
So long time reader first time poster. Had a 7.3 back in 04 and just bought my second. Its a early 99 SC LB 4x4 with 130k miles. Anyways the truck has a weird vibration only in a certain rpm range.
You can mostly feel it in 3rd and 4th when the engine lugs between 1300 and 1800 rpm. The vibration gets worse the more throttle I apply, when I let off it goes away. You can feel it in the whole truck but steering wheel shakes kinda bad also. I can also feel it a little in reverse. It wouldn't bother me but the vibration feels like its gonna break some tranny or motor mounts.
I've searched and read it could be anything from a bad injector to a torque converter shutter, but nobody posts if they resolved the problem. Has anyone had and resolved this issue? I'm getting kinda desperate but would hate to change the TC and it doesn't solve it. Any help is much appreciated and I'm glad to be back in the powerstroke family.
Justin.Hutch is offline
post #2 of 24 Old 01-17-2010, 05:33 AM
slopoe's Avatar
My truck does the exact same thing. my tranny and tc are new(less than 500 miles) if i drive mine for a while it will go away most the time but we did the cyl contribution test and my 3 & 8 injectors show to be bad. have you ran any test on it?
99 F250 Crew cab 4wd str8 pipe DIY intake 300k and counting
slopoe is offline
post #3 of 24 Old 01-17-2010, 02:19 PM Thread Starter
No I haven't done any tests yet. I just got the truck a few days ago. I've read multiple solutions to this problem, but the most common was injector related. Do you plan on replacing those injectors anytime soon?
post #4 of 24 Old 01-17-2010, 02:52 PM
Austinj427's Avatar
Those injectors read bad with a grey cps
Austinj427 is offline
post #5 of 24 Old 01-17-2010, 02:57 PM
slopoe's Avatar
Yes my new ones will be here tom. #3 read bad before ford did the cps recall then wk later 3 & 8 showed bad. Should i only replace 3?
slopoe is offline
post #6 of 24 Old 01-18-2010, 12:12 AM Thread Starter
After you've. Installed them please let me know if it helps at all.
post #7 of 24 Old 01-18-2010, 12:22 AM
Salebarn Rob's Avatar
If there is a stroke on the road that still hasn't had the cps upgrade then someone has been out of touch with civilzation. since you just bought the truck i would o strait to the for house to get it replaced and see about gettin a cylender contrubution test run as soon as the new one is in. alot of these ford techs are prettty cool and eager to share their knowledge.
Thanks to all the Techs! you guys keep me driving
Slaebarn Rob
2001 F350 Lariat
4 Dr, Dually
7.3 PSD, 6spd
AFE Stage II Cold air Intake
Magnaflow 4" Exhaust
Edge Evolution w/ Monitor
Wishlist: Stage I DDP injectors
TW 6 pos chip
Air Dog II
Wicked Wheel
Banks Fat-Head Wastegate Actuator
Salebarn Rob is offline
post #8 of 24 Old 01-18-2010, 02:34 PM
slopoe's Avatar
Installed my new injector in #3 today seems to have taken care of my miss did put the#8 in yet because it got broke during shipping but i will keep ya posted on how it does tom when its cold
slopoe is offline
post #9 of 24 Old 11-19-2012, 05:44 AM
Codum's Avatar
Did you ever find the problem? My truck is doing the same thing. My trans mission is under warranty, so dealer tried to fix the problem. They installed a new solenoid pack, new torque converter, then a new rebuilt transmission. None of this fixed the vibration. Told me the vibration was not transmission related. Trying to find out where to look next. Any suggestions much appreciated.
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #10 of 24 Old 11-19-2012, 05:54 AM
Codum's Avatar
Also, dealer said the injectors tested fine. Truck does not smoke outside of a hard acceleration or really cold starts. Dealer also reflashed the PCM with latest flash. Can I have a bad injector/s and not know it? No CEL, no codes, no smoke, passed buzz test. What can cause this vibration at 3rd and 4th at 1400-1800 rpm? It does it as soon as it shifts into 3rd or 4th, goes away once rpm's get up.
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
