Radiator Hose choice - Ford Powerstroke Diesel Forum
Old 01-14-2010, 03:45 PM
This weekend I'm going to be changing my serpentine belt due to it ripping a groove rib off. I'll be inspecting my all my pulleys.
But on to the question:
My upper hose now goes through the serpentine belt. I'm looking at Napa Auto parts and they show two upper hoses.
The first:
Store Locator | NAPA Online
Routes around the belt.
The second:
This one routes through the belt (like I have now)
I figure since I'm in there, I might change both upper and lower hoses. And I have to take the upper 'through' hose off anyway to get the belt changed. So...can I switch to the 'around' hose without any issues so I don't have to remove the hose again in the event I have a belt issue again?
Old 01-14-2010, 03:49 PM
duct tape & zip ties
Yes you can, I suggest you get a hose clamp. If you notice where the hose will go in front of the engine. You will see a spot where it looks like a hose clamp belongs to hold the hose away from the belt.
I did this switch already and it works great. So now when I need to remove the belt no need to drain and fill the radiator. Why Ford didn't do it like this first I do not know.
Old 01-14-2010, 07:30 PM
Sweet! Thanks a lot bigcountrysg!!! I was hopin' that would be the case. I'm probably due to change the coolant. Haven't changed it since I've had the truck. Summer towing season is coming.
Old 01-14-2010, 09:38 PM
I just changed out the radiator, water pump, upper and lower radiator hoses. I got the napa one that is for the dual alt setup (the one that goes around the serpentine belt). I ended up just using a zip tie to attach it to that little mount dealy so it's out of the way of the belt. It was only like 15 bucks.
Old 01-15-2010, 06:23 AM
Got Whistle?
Feedback Score: 5 reviews
This is one of those things every SD owner should do before you need to (along with the spare tire lock).
I changed to the 9066 a long time ago. Say you lose a belt going down the road....it's not going to do you any good to just be carrying a spare belt in the toolbox if the hose goes through the belt. Stupid design
Old 01-15-2010, 12:19 PM
I like you guys way of thinking!!!
Old 01-17-2010, 10:07 PM
Got my belt changed and installed the 9066 hose while I was at it. No more pulling the hose to change the belt.
Thanks for all your input - I appreciate it!
Old 01-19-2010, 10:06 AM
I also changed to the NAPA hose...they refer to it as the "preferred" hose, good chage....Fred
