Front end of motor grinding/nocking noise - Ford Powerstroke Diesel Forum
Old 01-13-2010, 04:42 AM
My truck started making a noise today and it almost sounds like a wheelbearing going bad but it does it while the truck is standing still in park. I opened the hood and looked inside everything lookes good. It sounds like could be the fan bearings or something in the front end of the motor that has a bad bearing any ideas. Is there anything else I should check I'm not getting any trouble codes nor is it lossing any power.
Old 01-13-2010, 07:39 AM
Water pump pulley is wobbling. Do I need to replace the entire water pump? How hard is it to replace the waer pump.
Old 01-13-2010, 02:06 PM
yes, replace the water pump. It comes as an assembly minus the fan. If you don't have the big tools to knock the fan loose, it's a lossing battle. If you decide to do it yourself and are not verrrrryyyy carful, you'll hit the radiator and knock a hole in it. Make sure th bottom rad hose gets removed and the rad flushed out. These engines have a LOT of sand in the water jacket. Probably what caused the problem.
Old 01-13-2010, 04:14 PM
Is there any one near Jacksonville, NC that would like to help out wrenching on my truck on saturday?
