Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #61 (permalink)
Old 02-23-2009, 11:31 PM
mechanic-luke42301 mechanic-luke42301 is offline
This exact problem is why i joined this forum. I have '99 7.3 that does the same. I replaced the wiper motor because it went bad. Never even considere that had anything to do with it. But the problem remains only when it rains or damp outside.
  #62 (permalink)
Old 02-24-2009, 05:27 AM
ktfjammer ktfjammer is offline
Do me a favor, go to fords recall list and put in your vin number. See if you have a recall that replaces your CPS. Have that changed and see what happens. You can not replace the CPS from anyone else but a Ford product. If you have already done so, when it rains do not do anything but drive it for a bit without putting on the wipers. After a while put on the wipers and find out what it will do. The other option is to take it to a shop and have the codes read. Hope this helps
  #63 (permalink)
Old 11-08-2009, 08:07 PM
dzlover dzlover is offline
You may want to check another thread on this forum which discusses a similar problem. Try looking at "stalls when it rains".
