Oil undertruck everywhere - Ford Powerstroke Diesel Forum
Old 01-09-2010, 10:59 AM
Hey guys im new to the forum but anyways i have a 2000 f350 and this morning i went out and it smelt like diesel real bad then i looked under the truck and theres puddles every everywhere and i did research its high pressure oil pump could be leaking so i looked in the vally of the motor looks wet is there any one from CT that could help me thanks guys
Old 01-09-2010, 11:01 AM
Im also having a oil leak, but there is a few things that can be leaking man. You have turbo pedistal o rings that can leak. The HPOP can leak in the quick connects. O rings are not very expinsive.
Old 01-09-2010, 11:05 AM
Is there a link to show how to change o-rings.. because i was just outside under the truck and the oil is coming from the front and between the block and tranny... so i dont know what it is...
Old 01-09-2010, 11:12 AM
Shaking the Bush Boss
if it was from the pedistol O rings...I wouldnt think youd see it coming from the frt of the motor. The valley has a weep hole in the back of it, so it can drain if there is anything collected in it. Good Luck
Old 01-12-2010, 04:18 PM
Alright so ive had it im going to replace the lines to the hpop anyone else done this??
Old 01-13-2010, 02:23 PM
And what if you replace those lines and get it back together and it is still leaking???
Take some time to clean the top of the eng good and let it dry. Get some really bright lites and inspection mirror. Start the eng for one minute, shut it off. Look, Look, Look. If you don't find the leak, start the eng again, go 2 minutes. You want fo find the very first place you can see the leak.. You could be leaking fuel and it's mixing with the crud on the intake and dripping off the eng, looks like oil.
Old 01-13-2010, 02:27 PM
shaking things up
possily an open drain on the fuel bowl if it smells like diesel fuel also when i blew my fuel press guage it looked like oil for a lil
Old 01-13-2010, 02:28 PM
Id never heard that about the fuel looking like oil... thats interesting.
Old 01-13-2010, 02:31 PM
OBS Forever!!!!!!
I agree don't blindly start replacing parts. I just installed my fuel pressure sending unit and cracked the fpr. The resulting little puddles looked exactly like crankcase oil.
