truck wont start - Ford Powerstroke Diesel Forum
Old 01-02-2010, 09:36 AM
truck wont start
Changed out the glow plug relay cause the truck was hard starting at -10*c. After the change then truck started awsome. Third start after swap the truck wont start, just cranks and cranks. The glowplug light no longer comes on either. Any ideas as to whats wrong?
Old 01-02-2010, 09:42 AM
seems like your PCM is not get power due to a shorted fuel heater, unplug fuel heater at fuel bowl,, replace fuse (can't remember which one) see if it starts
Old 01-02-2010, 10:23 AM
i checked the fuse and it was good...
Old 01-02-2010, 10:47 AM
fuel heater was uplugged, plugged it in and sill no start and no wait to start light
Old 01-02-2010, 11:17 AM
if your WTS light doesn't come on, your PCM is not powering up.......what setting is your chip on? i've heard of chips failing, or not making good contact....causing a no start
Old 01-02-2010, 11:21 AM
the chip was on the stock setting at the time. I have unplugged it now completely.
Old 01-02-2010, 12:02 PM
Powerstroke Techie
Check and see if the glow plug controller is getting power, and ground?
Does it have the solenoid style or the module style?
Old 01-02-2010, 12:14 PM
its the solenoid style. The 20 A maxi fuse for the pcm was blown... switched it with the one for the radio. Didnt start but wasnt plugged in. The relay is cracked on top so need to replace. Gonna try and start again after about an hr of being plugged in. Was about -20 - 30 *c here the last few days
Old 01-02-2010, 03:17 PM
Send a message via Yahoo to 01F35082AI
2001 F350 7.3 Powerstroke Turbo diesel super duty 4X4
I replaced belt,batteries,alternator and truck clicks a few times and stops won't turn over but batteries read good(hand held volt meter) the battery light stays on even when I do get it to start. Any help would be wonderful.
Old 01-12-2010, 12:14 PM
I know you said you replaced your alt but thats what my truck did when the alt went bad you may wanna double check the new one especially if its from orileys there remanufactured ones are from mexico and also check your fuse box on the inside of the engine bay theres a couple of fuses that could of blow I think the the 15a ones on the first row far left of the fuse box
