So I droped the tank on my truck at the suggestion of some of the folks on here. My pick-up is not clogged or anything. I got to thinking that if that is not it then what could it be. I poured diesel in to a pale and turned the key to on and let the pump suck fuel up. The in tank pick up is seems to be sucking air even when sunk in fuel ther-by not allowing me to build any fuel pressure. any ideas?
I've changed 3 sending units in 3 seperate 7.3s because of cracks in the pipes that suck air when the fuel level drops below the crack. Pressure will slowly drop as you accelerate until there is no pressure and the engine stalls.
Is the problem you are having is no fuel to filter, thats the issue I have on another post by me. I am afraid that is my issue trying to get as much info as possible. Looking into the itp fix for this with the external pre pump filter.
I got the tank all dropped and cleaned out. Took apart the pickup and cleaned the screans, did the "hutch mod", put a clanp on the pick up as mine was missing and it is supposed to have one, did the harppon mod and then put it all back in the truck in a lil less then 2 and a half hours. I reckomend everyone do this as it is very easy and dropping the tank is simple (if its empty) I did the whole thing myself.
I dont think it will be that easy in a excursion with a 44 gal tank, should i just buy the kit or build my own. Biodiesel is used in this when it is warmer so brass is a no no it will turn green. I think that kit was all stainless.
Ok finally got back to truck pulled the input line to fuel pump ran one down to small jar with diesel and nothing looks like pump is toast unless output line is clogged I would say very unlikely but I will check that after getting the fuel line removal tool to take the pump out.
ok its back on the road it was just the fuel pump new one is very quiet. I temped a electric fuel pump with built in bowl that I was going to use for my 94 hooked it to the line to the tank and it pulled very clean fuel. At this time my tank is ok primed the fuel bowl three times, and it started right up on that fourth try. Noticed one thing after it smoothed out that the engine seems quieter.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
