Truck died on the way home!! - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-01-2010, 02:51 AM Thread Starter
chopstx667's Avatar
Send a message via AIM to chopstx667
Exclamation Truck died on the way home!!
Great start to my new year! I was driving the truck home around 2:30 a.m. and I'm less than a half a mile away from home. The truck suddenly loss power, and felt like I was running out of fuel. Luckily I was able to pull off the road before it completely died.
I tried cranking the truck but it wouldn't turn over at all. I tried again but held the gas pedal down this time and it started really really rough, like the truck had a HUGE lope to it, and I had to hold the pedal down or else it would die. While it was started, the truck was blowing out a good amount of white smoke, does that mean it's fuel related? As soon as I left off the pedal, the truck would just die again. I had someone pick me up and just locked up the truck for the night, will be back in the morning to check if it's alright.
The truck was definitely warm since I was driving it for a good while, and I had just put in like 5 gallons of diesel earlier in the night. Could it also be because of a bad batch of fuel?
I'm gonna try to get it towed to a dealership tomorrow but just want to know what it could possibly and how hard it's gonna hurt the wallet
Thanks guys.
MY RIDE
2001 Platinum Edition 4x4
Fabtech 3.5 inch lift
35in BFGoodrich All-Terrains
Air Raid Intake
DP Tuner
Dual 6'' Aussies
ITP Boost Anihilator
Turbonetics BB
Set of Autometer Cobalts
more to come!!
WEEKEND TOY
1994 Acura NSX
chopstx667 is offline
post #2 of 16 Old 01-01-2010, 11:34 AM Thread Starter
chopstx667's Avatar
Bumpin to the top
MY RIDE
Air Raid Intake
DP Tuner
Dual 6'' Aussies
Turbonetics BB
more to come!!
WEEKEND TOY
1994 Acura NSX
post #3 of 16 Old 01-01-2010, 11:38 AM
Other vehicle is an F250
Hank's Avatar
Post up that you need someone with a scanner. Best way to figure it out.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #4 of 16 Old 01-01-2010, 12:10 PM
Broncoguy's Avatar
I agree a scanner is a good idea.
Could be bad fuel but I doubt it. Mine has done that in the past and it turned out that my UVC harnesses shook loose. Neighbors truck did the same but it took out his IDM too.
Wouldn't hurt to pop the valve covers and look before taking the dealer hit.
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #5 of 16 Old 01-01-2010, 12:11 PM
Hank's Avatar
I didn't say it but mine did it too and it was the UVC harness. Scanner "told" me though.
Hank is offline
post #6 of 16 Old 01-01-2010, 12:14 PM
Broncoguy's Avatar
UVC
If it turns out to be the UVC's, make sure and zip tie them in place before you put the valve covers back on. No more problems after that.
1999.5 F350
post #7 of 16 Old 01-01-2010, 12:15 PM
Hank's Avatar
I could not figure out how to zip tie them? I wish someone would show me a good picture of that. I replaced the side that gave me trouble. It snapped on tight.
Hank is offline
post #8 of 16 Old 01-01-2010, 12:33 PM Thread Starter
chopstx667's Avatar
Thanks guys, I'm gonna try to grab a scanner from a friend and see what's up with it. I just wish there was a way to get the truck home at the moment
MY RIDE
Air Raid Intake
DP Tuner
Dual 6'' Aussies
Turbonetics BB
more to come!!
WEEKEND TOY
1994 Acura NSX
post #9 of 16 Old 01-01-2010, 12:36 PM
Broncoguy's Avatar
UVC Zip tie
I am going to do a set of glow plugs for a buddy tomorrow, I will try and remember to snap some pics of the zip tie job.
1999.5 F350
post #10 of 16 Old 01-01-2010, 12:55 PM
Hank's Avatar
Thanks! I couldn't find anything to zip tie 'em to? Scott (Scuffy828) told me on the phone to just look and that there was no way he could explain it to me. )
Hank is offline
