white smoke and bogs down - Ford Powerstroke Diesel Forum
Old 03-30-2007, 06:19 AM
I just purchased a 1998 4x4 van with a PS. At startup there is no smoke, but after a few minutes, the engine will spew out white smoke (a whole lot of white smoke) and when I attempt to add more throttle the engine just bogs down and won't get to 1600 RPM, and still pours out the smoke.
I took the van to a shop and the mechanic says: may need valves, or there is oil in the turbo, or may need engine (then he says "I have a used engine..."). I have no confidence in the mechanics honesty, but I don't know a whole lot about PS myself.
What are likely causes of white smoke and inability to get RPM's out of the motor? When driving, the van will hardly pull itself.
Thanks
Old 03-30-2007, 06:26 AM
Is it even worth it???
Since I am not a tech.. I really can't help you with your problem. What I can do is bump this back toward the top for ya, so one of our techs is more likely to see it by saying:
Welcome to Powerstroke.org
Old 03-30-2007, 11:37 AM
Can't help you but i give you a bump back to the top and
Old 03-30-2007, 11:38 AM
Thanks for the "welcome", and the bump.
Old 03-30-2007, 11:39 AM
Can't give you an answer but will bump you back to top.
Old 07-10-2009, 06:45 PM
my 1998 powerstroke 7.3 smokes(blue/white) like crazy, and runs bad. The "water in fuel" light is on.
Old 07-10-2009, 06:57 PM
If the ban is smoking just wite then that is ether raw fuel or coolant. that is if it is just wite. and for the high jacker you injectors may be leaking or you may have sothing in you fuel sounds like to me.
Old 07-10-2009, 07:12 PM
Could be a blown turbo, when they go they shoot oil into the downpipe and it sends a white cloud out the tailpipe. Also it will not make and power most of the time.
Old 07-10-2009, 07:33 PM
7.3 is an all turbo engine, if the turbo is leaking oil that should be fixed first. The 7.3 is prettymuch bullet proof if you can keep a clean air filter in it.
Old 07-10-2009, 07:39 PM
Check the color of the fuel in your fuel bowl, if it looks black you have oil in your fuel. Oil in the fuel could be something as simple as bad/damaged injector O rings or the injectors themselves are bad. A more serious problem would be internally in your base engine, it would be a good idea to have crankcase pressure test performed. Also have the test performed on the turbo.
Do a thorough visual inspection of all your fluids, fuel, oil, coolant, and monitor their consumption.
