Collapsed Lifter - Ford Powerstroke Diesel Forum
Old 12-30-2009, 05:10 PM
Collapsed Lifter
Collapsed Lifter
01 7.3 w/ 150k Motor was smoking bad and rough idle origionally thought it was an injector. Pulled the passenger side valve cover and on #8 cylinder the front pushrod was loose laying in its hole its as straight as can be but not connected. Is it a collapsed lifter? And whats the easiest way to replace it? If the head HAS to be pulled it looks like I can maybe do it in frame, has any one done it? Didnt get a response in 911section
Old 12-30-2009, 05:26 PM
O.I.F. Combat Vet 11B
not sure but the head weights around a 100 lbs. so be careful!!
Old 01-01-2010, 05:04 AM
Yeah the head will have to be pulled. You should be able to do it in the frame....it will be fun, but doable.
Old 01-11-2010, 03:10 PM
What could have caused this? Like I said the pushrod is just laying there not connected straight as can be???? Is that forward valve on the #8 cylinder exh or int? Any other stuff that could be damaged w running it that way?
