Fuel Filter
The other day my fuel filter cap raise up on oneside of the fuel bowl with the rubber seal hanging out on one side.I dumped about 10 dollars of diesel on the ground. Well put another filter and cap on the truck. Boom did it again. I did have the Pressure raised up with the fuel shim. Took it out today to do some test drives to see if it will happen again. What are some of your thoughts on the matter?
how high was your fuel pressure with the shim?
I didnt check the pressure with a gauge,just went off specs of the write up on one of the threads that I saw. Number 6 machine screw one or something like that. Yea blew too caps in three days!
Has it done it since you went back to stock? You could of had the pressure too high.
I havnt gotten around to driving it yet. This happened Tuesday night,put new cap on it Wednesday morning drove around throughout the day and then Today Poof dumping fuel again. Ill drive around tomorrow and see if it goes again.
Yep truck did not like the fuel shimm(lol).
perfect example of why we should use agauge to see if were good or not. those filters aren't cheap.
