7.3 with no power! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-27-2009, 01:29 PM Thread Starter
honus22's Avatar
7.3 with no power!
Hey guys, I have two work truck's both 01 F350's with 7.3's, with auto's. Both of them have about 120k on them. My problem is, one of them runs like a raped ape and the other one is a turd!! I pull about 20k with them and the one acts like there is nothing behind it and the other can barley get out of it's own way! I service them every 4 to 5K, I have checked for air leaks, i can hear the turbo spool up, and now I'm not sure what it could be. Both trucks are stock. Any help would be great!!
honus22 is offline
post #2 of 14 Old 12-27-2009, 01:45 PM
storkerlovr's Avatar
exhaust break???
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
post #3 of 14 Old 12-27-2009, 01:46 PM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
my best advise would be to get the truck tested. buzz test, cylinder contribution test. That will get you going in the right direction as to what is goin on.
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
post #4 of 14 Old 12-27-2009, 01:48 PM Thread Starter
honus22's Avatar
No exhuast break.
honus22 is offline
post #5 of 14 Old 12-27-2009, 01:51 PM
pinkfloyd's Avatar
where are you located? maybe someone on here can scan the truck for you.
stock tranny
DP-Tuner F6 chip
valve body
boost fooler
NEXT ON LIST
torque converter
post #6 of 14 Old 12-27-2009, 01:53 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
fuel pressure , filters
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #7 of 14 Old 12-27-2009, 01:57 PM
2whlfreak's Avatar
Did this just happen?
2whlfreak is offline
post #8 of 14 Old 12-27-2009, 05:52 PM Thread Starter
honus22's Avatar
I live in eastern iowa, 25 min west of Iowa City. Not sure what its runing for fuel pressure, and it just had all the filters changed. We have had the truck for prolly two years, and it's allways ran like this. It get's drivin every day, so its not like its so bad that it can't go down the road. I just don't understand why the two trucks are like night and day.
honus22 is offline
post #9 of 14 Old 12-27-2009, 05:57 PM
silverF250's Avatar
One's probably chipped the other isn't.
Pat
2000 F250 Carpenter's Union local 2214
LOOKING FOR SIDE JOBS
Mac intake,5" exhaust with6" tip,Zoodad,foil delete, ts chip, WW
96 E350 bad trans mod NO MORE.
silverF250 is offline
post #10 of 14 Old 12-27-2009, 06:02 PM Thread Starter
honus22's Avatar
I have put a programer in both of them. The one run's even harder than it allready does, so i took it back out because it dosn't need it. When I put it in the turd it runs a little better, but not as good as the other at stock!
honus22 is offline
