Trouble with engine - Ford Powerstroke Diesel Forum
Old 03-28-2007, 08:29 AM
Trouble with engine
1995 PSD, scanned for rough running, indicated the fuel air metering auxiliary emissions control. Also indicated No DTC definition found, refer to service manual. OK, truck starts, runs rough, does not respond to throttle, engine check light on, sometimes will run good, intermittently check engine light goes off, then back on and rough running continues. What is fuel air metering Auxiliary Emissions control, where is it, what does it do, how can I fix it. Repairs so far, replaced wiring under valve cover on cyl 6 & 8, new valve cover gasket, complete injector/glow plug fuel wiring harnass on top of engine. Please, somebody talk to me, I'm going nuts here!
Old 03-28-2007, 08:46 AM
lifetime member
help
i am sure someone will be along that can help. i will ckeck back after work and bump this back up if no response.
Old 03-28-2007, 10:35 AM
Powerstroke Techie
Post the codes. Don't know where you are getting the definitions of the codes but they don't sound correct. Sounds like those codes are for a gasser.
Old 03-28-2007, 11:26 AM
scanner gives P0000 code 238, mod$B9 1/238, acutron scanner, doesn't look like anything to me, I am contacting Acutron about their scanner.
Old 03-28-2007, 11:39 AM
Powerstroke Techie
Those are deffinatley not good codes.
